Welcome,
In such instances it would be wise to use bolts and nuts with spreader plates top and bottom to distribute the load over a larger area of the wood.
There may be uploading with wind lift as well as down loading. Depending on load, 3/16" to 1/4" steel plates the width of the wood and maybe 1.5 x width in length should suffice. Use a flat washer and spring washer under the nut.
