UN External Screw Threads Formulas and Calculator
ANSI Hardware Design Guide and Charts
Unified Inch Screw Threads Calculator for UN Threads
Inch Size UN External Screw Threads Formulas and Calculator per. ASME B1.1
The formulas below are for inch screw threads are based on those listed in ASME B1.1, Unified Inch Screw Threads.
For internal threads see:
Screw Threads Calculator for Internal Unified Inch Screw
Formulas Used:
Note that calculated values may be slightly different than table reference
data due to math rounding differences.
Maximum external major diameter
dmax. = dbsc − es
where
dbsc = Basic major diameter
es = Allowance
- Classes 1A and 2A, es = 0.300 & Class 2A pitch diameter tolerance
- Class 3A, es = no allowance
Major Diameter Tolerance
(1 ) Class 1A = 0.090 P2/3
(2) Classes 2A and 3A = 0.060 P2/3
The tolerance for Class 2A coarse and the 8-thread series threads of unfinished,
hot-rolled material is0.0903P2/3.
This does not apply to standard
fasteners with rolled threads.
Minimum dia major diameter
Eq. 3
dmin. = dmax. − Td
where
Class 1A Td = 0.090 P2/3
Classes 2A and 3A Td = 0.060 P2/3
hot-rolled material is0.0903P2/3. This does not apply to standard
Maximum external pitch diameter
Eq. 4
d2max. = dmax. − 2has
where
dmax = Maximum external major diameter
2has = 0.64951905P
Minimum external pitch diameter
Eq. 5
d2min. = d2max.
− Td2
where
d2 = 0.0015 (d bsc)1/3 + 0.0015 LE1/2 0.015 (P2)1/3
Maximum external UNR minor diameter
Eq. 6
d3max. = dmax. − 2hs
where
2hs = 1 .19078493P
dmax. = Maximum external major diameter
Maximum external UN minor diameter
Eq. 7
d1max. = dmax. − 2hs
where
2hs = 1 .08253175P
LE = length of engagement
P = thread pitch = 1/n
n = number of
threads per inch
Notes
External Thread
(a) Maximum Major Diameter (External Threads)
(1 ) For
Classes 1A and 2A, d = basic major diameter, Dbsc, minus allowance.
(2) For
Class 3A, d = basic major diameter, Dbsc.
(b) Minimum Major Diameter (External Threads). For all classes, equals maximum major diameter, minus major diameter tolerance for respective class of thread.
(c) Maximum Pitch Diameter (External Threads)
(1 ) For Classes 1A and 2A,
d2 =basic pitch diameter D2bsc, minus allowance.
(2)
For Class 3A, d2 = basic pitch diameter D2bsc.
(d) Minimum Pitch Diameter (External Threads). For all classes, equals maximum pitch diameter, minus pitch diameter tolerance for respective class of thread.
(e) Maximum Minor Diameter (External Threads). In dimensioning UN series external threads, the minor diameter is not specified. In practice, the minor diameter is satisfactory when accepted by a standard GO thread gage in accordance with ASME B1.2. When it is desirable to obtain minor diameter values for reference purposes and for UNR threads, they can be calculated as follows:
(1 ) For UN series threads, the formulas are:
(a) for Classes 1A and 2A, d1
= basic minor diameter D1bsc, minus allowance
(b) for Class 3A, d1
(2) For UNR series threads, the
formulas are:
(a) for Classes 1A and 2A, d3 p basic minor diameter D1bsc,
minus allowance, minus H/8
(b) or Class 3A, d3 = basic minor
diameter D1bsc, minus H/8
(f) Minimum Minor Diameter (External Threads). When it is desirable for design purposes to calculate the minimum diameter, it can be obtained for all classes by the formula: minimum pitch diameter minus 0.64951905P.
