Pipe Thread Pitch Diameter Formulas and Calculator
Standard ANSI Hardware
Pitch Diameter Formulas and Calculator NPT American National Standard Taper Pipe Threads
Tapered Pipe Pitch Diameter Calculator Preview
E0 = D - ( 0.05 D + 1.1 ) p
E1 = E0 + 0.0625 L1
L2 = (0.80 D + 6.8 ) p
Eo = pitch diameter at end of pipe;
E1 = pitch diameter at the large end of the internal thread and at the gaging notch;
L1 = length of hand-tight or normal engagement between external and internal thread;
L2 = basic length of effective external taper thread;
D = outside diameter of pipe;
p = pitch = 1 ÷ number of threads per inch.
Form of Thread: The angle between the sides of the thread is 60 degrees when measured in an axial plane, and the line bisecting this angle is perpendicular to the axis. The depth of the truncated thread is based on factors entering into the manufacture of cutting tools and the making of tight joints.
Thread Length: The formula for L2 determines the length of the effective thread and includes approximately two usable threads that are slightly imperfect at the crest. The normal length of engagement, L1, between external and internal taper threads, when assembled by hand, is controlled by the use of the gages.
Taper: The taper of the thread is 1 in 16, or 0.75 inch per foot, measured on the diameter and along the axis. The corresponding half-angle of taper or angle with the center line is 1 degree, 47 minutes.
ANSI/ASME B1.20.1-1983 (R2006), American National Standard Taper Pipe Threads
