Converting Sound Power to Sound Pressure Formulas and Calculator
Civil Engineering and Design
Design Applications
Designers are often required to use sound power level information of a source to predict the sound pressure level at a given location. Sound pressure at a given location in a room from a source of known sound power level depends on:
- room volume,
- room furnishings and surface treatments,
- magnitude of sound source(s),
- distance from sound source(s) to point of observation, and
- directivity of source.
The classic relationship between a single-point source sound power level and room sound pressure level at some frequency is
Equation 1
Lp = Lw + 10 log(Q/4πr2 + 4/R) + 10.3
Lp = sound pressure level, dB re 20 µPa
Lw = sound power level, dB re 10-12 W
Q = directivity of sound source (dimensionless)
r = distance from source, ft
R = room constant, Sα /(1 – α) Equation 2
S = sum of all surface areas, ft2
α = average absorption coefficient of room surfaces at given
frequency, given by:
Equation 3
α = ∑i = Siαi / ∑iSi
where Si is area of ith surface and αi is absorption coefficient for ith surface.
If the source is outdoors, far from reflecting surfaces, this relationship simplifies to:
Equation 4
Lp = Lw + 10 log(Q/4πr2) + 10.3
This relationship does not account for atmospheric absorption, weather effects, and barriers. Note that r2 is present because the sound pressure in a free field decreases with 1/r2 (the inverse-square law; see the section on Sound Transmission Paths). Each time the distance from the source is doubled, the sound pressure level decreases by 6 dB.
- Acoustic Sound Pressure Level Chart
- Acoustic Definitions and Terms
- Sound System Design Equations
- Speed of Sound Table Chart
- Warnock 1997, 1998a, 1998b)
- AHRI Standard 885
