Section Modulus Channel Section Neutral Axis at Center Equation and Calculator
Section Modulus Equations Calculators Common Shapes
Section Modulus Calculator and equation for channel section with center neutral axis. Other geometric properties used in design include area for tension, radius of gyration for compression, and moment of inertia for stiffness. Any relationship between these properties is highly dependent on the shape in question.
Notes:
Keep units consistant for the input design variables inches or mm.
Channel Section Modulus Section Modulus Channel
This calculator Requires a Premium Membership
www.engineersedge.com
Advertising | Contact
