Bolt Circle With Even Number of Holes Within Circle Measurement and Conversion Calculator
Strength of Materials
For More equations and illustrative graphics see:
Measuring Large Bolt Circle Equations and Review
Even Number of Holes Within Circle: To measure or determine the unknown distance x over opposite pins (largest gage pins that can fit into holes) within a bolt circle of holes (n or number of bolts holes must be even and greater than 4), as shown left in Illustration A, use the equation:
y = the distance over alternate pins
d = the diameter of the holes
θ = 360°/n or angle between adjacent holes.
All units shall be consistant and given in inches or mm. Angles (theta) are given in degrees
Variables
Distance over alternate pins (y) =
Diameter of holes (d) =
Angle between adjacent holes (Theta) =
Results
Distance over opposite pins (x) =
Automatic recalculation
