Bending, Deflection and Stress Equations Calculator for Beam Supported on Both Ends Uniform Loading
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on Both Ends with Uniform Loading Stress and Deflection equations and calculator.
Beams of Uniform Cross Section, Loaded Transversely
Total Load ("W")
or
Line Pressure Load (p)
Open
Beam Deflection, Stress Uniform Loading Calculator
Beam Stress at any point
Beam Stress at center of constant cross section
Beam Deflection at Any Given Point
Maximum Beam deflection at Center
With Total load "W"
or
With Line Pressure Load "p"
l = | Length of Beam | inches | (mm) |
W = | Total Load on Beam | lbs | (N) |
p = | With Line Pressure Load | psi-in | (N/mm) |
s = | Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
Z = | section modulus of the cross-section of the beam = I/z | in3 | (mm3) |
z = | distance from neutral axis to extreme fiber (edge) | inches | (mm) |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 404 or,
- Machinery's Handbook, 23st Edition, Page 260 or,
- Machinery's Handbook, 27st Edition, Page 261 or,
- Marks Standard Handbook for Mechanical Engineers, Tenth Edition 1996, Page 297 (Table 5.2.2)
- Mechanical Engineers Handbook, Edited by Myer Kutz, John Wiley & Sons, Inc., 1986, Page 414
- Eshback, Handbook of Engineering Fundamentals, Third Edition, Wiley Engineering Handbook Series, 1974, Page 518
- Mechanics of Materials, Ferdinand P. Beer & E. Russel Johnston, Jr. ISBN0-07-004291-8
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Reversed Limited Tapered Load
- Beam Supported One End, Pin Opposite End and Partial Distributed Load Deflection, Shear and Stress Equations and Calculator
- Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated.
- Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
- Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
- Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
- Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
