Related Resources: Software Applications
Stress Strain Curve Plotting Calculator Python Application
Stress Strain Curve plotting using Python Calculator
Premium Membership Required
Download: Stress Strain Curve plotting Python Calculator
Features
- Plot Stress Strain Curve using Load and Elongation Data.
- Offset Line for yield stress is automatically plotted.
- Max Stress, UTS, Max Strain calculation.
- Edit Curve.py file
- Customizable and much more...
# define your values start
Force = [0,4400,5670,6600,7040,8320,8800,9200,9240]
Elongation = [0,1,2,4,5,8,10,15,18]
GLength = 75
Radius = 6.65
LinearLimit = 1
# define your values end
Figure 1 - Generated Stress Strain Curve
How to Use
- Install a Python compiler
- Open Curve.py
- Install the required Python packages
- Adjust the data as required
- Run the program
- Save the Output!
Source
- Thickness of Wall and Ejector Marks Tolerance Calculator Grade E per. EN-10243-1 for Non-Circular Forgings
- Wall Thickness and Ejector Marks Tolerance Calculator Grade E per. EN-10243-1 for Circular Forgings
- Thickness and Ejector Marks Tolerance Calculator Grade F per. EN-10243-1 for Circular Forgings
- Thickness and Ejector Marks Tolerance Calculator Grade F Forgings
- Circular Forgings Tight Tolerance Calculator per. EN-10243-1
- Tolerance Table for Regularly Used Fits Excerpt from JIS B 0401 Table Calculator
- Snap Fit Tapered Finger Stress Application Calculates the Dynamic Strain of a tapered cantilevered flexing finger typically used in plastic snap fit type designs.
- Snap Fit Straight Finger Stress Application Straight beam dynamic strain equation and calculator
- Plastic Post and Hub Press Fit Equations / Calc. Press fits can be used with similar or dissimilar materials and can eliminate screws, metal inserts, adhesives, etc.
- Plastic Screw Design Equations and Calculator Theoretical equations to calculate the strength of plastic screwed joints.
