Tolerance Stack Analysis Methods
Geometric Tolerances, Limits Fits Charts, Mechanical Tolerances Tables and Calculators
Fritz Scholz
Research and Technology
Boeing Information & Support Services
Free Membership Required for this White Paper
Open: Tolerance Stack Analysis Methods
The purpose of this report is to describe various tolerance stacking methods without going into the theoretical details and derivations behind them. For those the reader is referred to Scholz (1995). For each method we present the assumptions and then give the tolerance stacking formulas. This will allow the user to make an informed choice among the manya vailable methods.
The methods covered are: worst case or arithmetic tolerancing, simple statistical tolerancing or the RSS method, RSS methods with inflation factors which account for nonnormal distributions, tolerancing with mean shifts, where the latter are stacked arithmeticallyor statisticallyi n different ways, depending on how one views the tradeoff between part to part variation and mean shifts.
Introduction and Overview
Tolerance stack analysis methods are described in various books and papers,
see for example Gilson (1951), Mansoor (1963), Fortini (1967), Wade
(1967), Evans (1975), Cox (1986), Greenwood and Chase (1987), Kirschling
(1988), Bjørke (1989), Henzold (1995), and Nigam and Turner (1995). Unfortunately,
the notation is often not standard and not uniform, making the
understanding of the material at times difficult. For a critical review of these
and some new methods and the mathematical derivation behind them see
Scholz (1995)
- Tolerance Stackup Analysis
- Three Mating Features GD&T Tolerance Analysis at MMC Calculator
- GD&T Two Mating Diameters Tolerance Analysis at MMC Calculator
- Engineering, Manufacturing Tolerance Limits Fits Charts | ISO 286 Tolerances | Metric Tolerance Chart
- Assembly Tolerance Analysis Calculator
- Bolt Spacing Tolerance Analysis Formula and Calculator
